Can you use Exp pedal switch as on/off for non pedal effects?
Gawwuf
I don't think there are any non expression pedal effects, or parameters, in Helix. But I get what you mean, wah, volume, pitch glide, etc.
So select the effect, hit the menu button, press footswitch assign, then turn the encoder till it says EXP Toe.
Yes, but since there's no capacitive touch circuit in the toe switch (for obvious reasons), you have to assign the blocks manually from the Footswitch Assign screen:
  1. Press MENU and then Knob 1 (Footswitch Assign).
  2. Select the block you wish to assign and then turn Knob 1 (Footswitch) to "EXP Toe."
