PiFromBRC Posted October 27, 2015 Share Posted October 27, 2015 I use two amps. A Marshall 800 and a Roland Cube. I do smaller gigs, so the volume is fine, but I do like to play in stereo. I am curious if I can use the 4CM on the Marshall and the front panel on the Cube (no loop available for that) and somehow balance the signals so I don't get a high STNR out of either amp. Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted October 27, 2015 Share Posted October 27, 2015 This should be easy to accomplish with 2 separate paths. Set up the 4CM in the usual way. Create a second path and use another one of the Helix fx sends to go out to the Cube. Quote Link to comment Share on other sites More sharing options...
PiFromBRC Posted October 28, 2015 Author Share Posted October 28, 2015 This should be easy to accomplish with 2 separate paths. Set up the 4CM in the usual way. Create a second path and use another one of the Helix fx sends to go out to the Cube. Cool. Thanks much! Quote Link to comment Share on other sites More sharing options...
