taleslr
Fx100 With Blackstar ht stage 60
Hi
I'm buying a new amp, Blackstar ht stage 60 to use with my fx100.
My idea was to have two different setups:
1 - main out into amp input, using effects withou amp simulation
2 - main out to effect loop using amp simulation
Swapping between those two with a ABY pedal!
Question are: are those two setups ok for the amp and the pedal? Can I swap between those two setups with the amp on without damaging the amp?
Thanks for your inputs!
Regards!
Hi there,
This is a great set up.
This is completely safe, and common to do. The FX loop does not send a loaded signal.
