pob41 Posted November 8, 2015 Share Posted November 8, 2015 Put a belting patch together tonight using the Fern A30 and J45 Amp+cab amps. Used a comp, eq, stereo delay and reverb. Sounded great but couldn't add anything else, the DSP was maxed. I understand the limitations and the manual refers to how all the different amps and effects make variable use of the DSP, but are there any guidelines on the DSP demands? Which amps and effects use the most DSP and which the least? Some insight would be very useful. Thanks! Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted November 8, 2015 Share Posted November 8, 2015 Keep in mind that each path (1 and 2) have their own processing. If you fill up path 1, you've still used up less than 50% of the total available DSP. Route path 1 into path 2 and you're golden. Quote Link to comment Share on other sites More sharing options...
pob41 Posted November 8, 2015 Author Share Posted November 8, 2015 Hadn't realised this but that's great news. Thought I was missing something somewhere. Thank you! Quote Link to comment Share on other sites More sharing options...
kensington Posted November 8, 2015 Share Posted November 8, 2015 Keep in mind that each path (1 and 2) have their own processing. If you fill up path 1, you've still used up less than 50% of the total available DSP. Route path 1 into path 2 and you're golden. Good to know:) Is there any way of using all 4 rows as a signal chain (without using it as a parallell)? Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted November 8, 2015 Share Posted November 8, 2015 Good to know:) Is there any way of using all 4 rows as a signal chain (without using it as a parallell)? Yep, just check out the preset TEMPLATES -> 01D Super Serial for an excellent example. Quote Link to comment Share on other sites More sharing options...
kensington Posted November 10, 2015 Share Posted November 10, 2015 Yep, just check out the preset TEMPLATES -> 01D Super Serial for an excellent example. Tnx. I don't have the unit here...usually in the tour bus. But I'll look at it :-) I've trying to get the signal to go to row 2 (out of 4), but haven't succeeded yet. Wonder how you can force it into 4 rows:) Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted November 10, 2015 Share Posted November 10, 2015 Tnx. I don't have the unit here...usually in the tour bus. But I'll look at it :-) I've trying to get the signal to go to row 2 (out of 4), but haven't succeeded yet. Wonder how you can force it into 4 rows:) Highlight one of the amps or effects on path 1A, press ACTION, drag it down and it will create path 1B, press ACTION again to release it. You'll notice that 1B splits from 1A but merges later on down the path. If you select the point that it merges (merge block), you can press ACTION to drag it down so that 1B has it's own output and doesn't merge back into 1A. Go to the output block for 1A or 1B, rotate the joystick to route it to path 2A. Highlight one of the amps or effects on path 2A, press ACTION, drag it down and it will create path 2B, press ACTION again to release it. Quote Link to comment Share on other sites More sharing options...
kensington Posted November 10, 2015 Share Posted November 10, 2015 Highlight one of the amps or effects on path 1A, press ACTION, drag it down and it will create path 1B, press ACTION again to release it. You'll notice that 1B splits from 1A but merges later on down the path. If you select the point that it merges (merge block), you can press ACTION to drag it down so that 1B has it's own output and doesn't merge back into 1A. Go to the output block for 1A or 1B, rotate the joystick to route it to path 2A. Highlight one of the amps or effects on path 2A, press ACTION, drag it down and it will create path 2B, press ACTION again to release it. Hm...but this sounds like parallell though, not all 4 in series? So, 1A with a chain (1B) and 2A with a chain (2B). I want guitar in -> A, B, C, D->output. But i'll check the unit tomorrow:) Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted November 10, 2015 Share Posted November 10, 2015 I want guitar in -> A, B, C, D->output. 8 TEMPLATES > 01D Super Serial x2 is exactly this. Page 18 in the manual explains how to build it manually. Quote Link to comment Share on other sites More sharing options...
kensington Posted November 10, 2015 Share Posted November 10, 2015 8 TEMPLATES > 01D Super Serial x2 is exactly this. Page 18 in the manual explains how to build it manually. Ah. Great. Just found the manual now. It wasn't delivered with my Helix, but I found a PDF online :-) Tnx! Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted November 10, 2015 Share Posted November 10, 2015 Ah. Great. Just found the manual now. It wasn't delivered with my Helix, but I found a PDF online :-) Tnx! Yep, that's what I was trying to explain. The manual does a much better job though. Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted November 10, 2015 Share Posted November 10, 2015 Ah. Great. Just found the manual now. It wasn't delivered with my Helix, but I found a PDF online :-) Tnx! Was the USB flash drive missing from your box? Quote Link to comment Share on other sites More sharing options...
kensington Posted November 10, 2015 Share Posted November 10, 2015 Was the USB flash drive missing from your box? No. Is the manual on it? Haha...I never checked the drive...thought it was free commercial flash drive :D 1 Quote Link to comment Share on other sites More sharing options...
