derek2210 Posted November 9, 2015 Share Posted November 9, 2015 Hi, My Pod Pro is not working, which I have found to be the transformer soldered to the PCB inside the case has somehow been damaged, there is no power comming out of the transformer. I am a Electronics Engineer and have removed the transformer from the PCB. Please see attached photograpgh Can I buy a new transformer? Quote Link to comment Share on other sites More sharing options...
Rhythmanmusic Posted December 14, 2015 Share Posted December 14, 2015 Hi, I also had a prob with the transformer in my PRO which I managed to fix. However, I got in touch with Line 6 to ask if I could purchase 1 and was told they no longer stock replacements and he referred me to buy a 2nd hand pro on e Bay etc. Not sure if any other Co makes a transformer which is compatible as didn't look any further as a small solder job got my one going again. I did pick up a pro on e bay for a good price as a backup so this might be the route to go down. Cheers Quote Link to comment Share on other sites More sharing options...
sparker1 Posted December 28, 2015 Share Posted December 28, 2015 The internal transformer is a 9V AC secondary type, I replaced my broken transformer (shorted primary) with a 9V AC output toroid transformer. I soldered the leads directly onto the PCB and cable tied it in place. Make sure the primary is the correct voltage for your mains input. Mike :rolleyes: 1 Quote Link to comment Share on other sites More sharing options...
BillBee Posted December 29, 2015 Share Posted December 29, 2015 Thanks for the new Mike! Never know when that will come in handy. Welcome to the board too btw! -Bill Quote Link to comment Share on other sites More sharing options...
ziggyblunt2016 Posted October 9, 2016 Share Posted October 9, 2016 Hi, My Pod Pro toke a dive from the shells couple of years ago and ruined the transformer. Also I'm looking for an alternative.... originally there probably from a company called EnsignCorp! But they probably have some contract with line6 not to sell the specific one we need.. http://www.ensigncorp.com/ProductDetails.aspx?ProductID=64&AttributeID=620 20VA IP020-2-020 115/230V 20VCT @ 1.0A 10V @ 2.0A Data Sheet Maybe this is useful for anyone who still like me uses stuff from the stone-age :) Greetz Ziggy Quote Link to comment Share on other sites More sharing options...
capobeat Posted July 19, 2018 Share Posted July 19, 2018 Hi, my transformer fell off. It was only fixed to the board with a cable binder (!). Which way do I need to place it? There is one side with a '1' and the other side marked with a '3'. Any hints? Thanks very much. K Quote Link to comment Share on other sites More sharing options...
mellowmike Posted October 6, 2020 Share Posted October 6, 2020 On 12/28/2015 at 4:39 AM, sparker1 said: The internal transformer is a 9V AC secondary type, I replaced my broken transformer (shorted primary) with a 9V AC output toroid transformer. I soldered the leads directly onto the PCB and cable tied it in place. Make sure the primary is the correct voltage for your mains input. Mike :rolleyes: Mike - could you point me to the one that you used online (if you can remember)? There are so many choices out there, and I'd like to be sure I get a proper replacement. Was it something like this one... https://americas.rsdelivers.com/product/myrra/44128/9v-ac-2-output-through-hole-pcb-transformer-2va/1739721 I assume it has to be 9v output... and not 10v... Thanks, Mike Quote Link to comment Share on other sites More sharing options...
A4345LINE Posted August 29, 2021 Share Posted August 29, 2021 Any news on transformers? The POD XT PRO I have has a large xformer bolted to metal bottom and has 2 (out, I guess) yellow wires (AC 9V?) and a multipin input cable. RD YEL BLU WHI BLK this thing is HOT, and unit reboots and flashes! Let me know, will send beer. Phillip Quote Link to comment Share on other sites More sharing options...
