GuitarGuru83 Posted December 22, 2015 Share Posted December 22, 2015 Hey guys I was wondering if I could use the firehawks USB connection to plug into GarageBand and instead of using the firehawks amps and effects And use the Amplitube 4 via USB with no firehawk Quote Link to comment Share on other sites More sharing options...
ppiluk Posted December 23, 2015 Share Posted December 23, 2015 I think you would be better suited to purchasing a dedicated audio interface. however, as long as you turn off all the effects and amps on the Firehawk you should be able to use it with Amplitube. Your best bet would be to try it. I have quite a large collection of Amplitube amps and pedals, in fact I have about 90% of them. I like Amplitube and use it for recording sometimes. If you have any investment of cash into Amplitube, you should look at a proper audio interface. Quote Link to comment Share on other sites More sharing options...
GuitarGuru83 Posted December 23, 2015 Author Share Posted December 23, 2015 i ask because it states "USB connectivity and ultra-low latency, Firehawk FX is also an ideal guitar recording interface for PC, Mac® and iOS.*" on the front page, so i assumed it would work as an interface for other software based multifx programs Quote Link to comment Share on other sites More sharing options...
ppiluk Posted December 23, 2015 Share Posted December 23, 2015 I have used the Firehawk to record using Garage Band and Cubase and it is an excellent tool. I have never turned off all the effects and the amp to use Amplitube 4. Quote Link to comment Share on other sites More sharing options...
danwin22 Posted December 20, 2016 Share Posted December 20, 2016 In amplitube they have the bypass feature to get clean guitar sound. Couldn't I connect my firehawk to Amplitube and use the bypass feature to use amplitube as a speaker for my firehawk? Thus getting me the pure effects and amps in the firehawk without interference? Quote Link to comment Share on other sites More sharing options...
ADBrown Posted December 21, 2016 Share Posted December 21, 2016 If the signal is sent into amplitube and there is no further processing or modeling done to the signal then it sounds like you would be setup to get the pure signal from firehawk. Quote Link to comment Share on other sites More sharing options...
danwin22 Posted December 22, 2016 Share Posted December 22, 2016 When I plug into amplitube it shows that it is recognizing my Firehawk fx and if I strum my guitar which is plugged into firehawk I can see the gauge in amplitube showing it is getting my guitar sound. But, for some reason I can't hear anything through my computer speakers. Any suggestions? Same thing happens when I use usb and plug into audacity. No sound from firehawk but it shows input as firehawk and output is my speakers. ????? Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted January 2, 2017 Share Posted January 2, 2017 Your speakers need to be plugged into the firehawk when using it as your interface Quote Link to comment Share on other sites More sharing options...
