masterwolf Posted February 3, 2016 Share Posted February 3, 2016 My music plays to match tones but the sound doesn't come through my amp. Any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 3, 2016 Share Posted February 3, 2016 On what device is your music playing? You need it to be playing form the music player in the AMPLIFi app running on your mobile device, which is connectd via Bluetooth to your amp. Quote Link to comment Share on other sites More sharing options...
RingoCalamity Posted March 19, 2016 Share Posted March 19, 2016 I'm having this issue too. I have an Amplifi TT running into my Fender Blues Jr. The guitar stuff all works fine, but when I play music (using the Amplifi amp on my HTC M8), no sound comes out whatsoever. The app shows the music as playing (track time starts counting), but there's no audio. Any solutions to this? The Amplifi TT is fully updated, I've restarted my phone, etc. Quote Link to comment Share on other sites More sharing options...
vmoncebaiz Posted March 20, 2016 Share Posted March 20, 2016 In your Amplifi Remote app, check settings > device selection. Turn on advanced settings. You can choose if you want the sound to come from the device or the Amplify unit. Quote Link to comment Share on other sites More sharing options...
RingoCalamity Posted March 20, 2016 Share Posted March 20, 2016 When I did that, there was no sound whatsoever coming from the amp - only the phone setting gave any sound at all (through the phone). I solved this by putting my TT output through the headphone jack to the amp instead of using the amp out. It works. Quote Link to comment Share on other sites More sharing options...
AlexLiew61 Posted July 24, 2017 Share Posted July 24, 2017 I'm using Samsung S7 having same problem, music play with Amplifi Remote App, but music sound doesn't out, only guitar tone sound. Anyone can help? Quote Link to comment Share on other sites More sharing options...
scott93105 Posted September 19, 2017 Share Posted September 19, 2017 I'm having the same issue with FX-100. Quote Link to comment Share on other sites More sharing options...
alarocco Posted December 26, 2017 Share Posted December 26, 2017 When I did that, there was no sound whatsoever coming from the amp - only the phone setting gave any sound at all (through the phone). I solved this by putting my TT output through the headphone jack to the amp instead of using the amp out. It works. I just got my Amplifi TT. With preloaded firmware, I got the Demo backing tracks to play through my amp, through amp output. After upgrading to latest FW (2.6.1) there was no sound through amp output, but headphone jack worked. Thanks very much, but I can't believe Line6 screwed that up. Quote Link to comment Share on other sites More sharing options...
cbrillow Posted December 27, 2017 Share Posted December 27, 2017 They didn't screw this up. To put it simply: RTFM There are several possible connections, and they behave differently. It takes a little while to exhaust all the possibilities, and it can seem confusing, at first. Here are the relevant sections: Rear Panel Connections 1 Amp Out -The Amp Out provides a 1/4 inch mono output of guitar processed with amp modeling and effects and optimized for connecting to the input of a guitar amp. Bluetooth audio is not sent to the Amp Out. Using Main Outs & Amp Out Together - Only Bluetooth audio will be present at the Main Outs when the Amp Out jack is connected. RCA Main Outs -The RCA Main Outs provide full range audio, sending out a mix of processed guitar and any Bluetooth audio that may be streaming to the unit. Plug RCA cables to the RCA Main Outs to connect to any number of destinations, such as a home stereo or portable speaker system. 1/4 inch Main Outs - The 1/4 inch Main Outs also provide full range audio, sending out a mix of processed guitar and any Bluetooth audio that may be streaming to the unit. Plug 1/4 inch cables into these outputs to connect to a destination with 1/4 inch inputs, such as a mixing console, PA or powered monitors. In other words, if you are connecting to a guitar amp using the Amp Out jack, you will not get streamed BT audio. Streamed BT audio will be available from either the RCA or 1/4" Main Output jacks. The processed guitar signal will also be present here UNLESS you also have a connection to the Amp Out. In this case, the signal will be split, with the guitar coming out of the Amp Out, and BT audio from the Main Outs. Yes, another option is to use the headphone output, but I'm not going to break that down. Quote Link to comment Share on other sites More sharing options...
