gitaarhopper Posted February 5, 2016 Share Posted February 5, 2016 How do I set the default master volume on the FX100? The volume is now very soft when I turn it on. He does not hold the set volume. greetings, Jan Quote Link to comment Share on other sites More sharing options...
NBell Posted February 16, 2016 Share Posted February 16, 2016 Hi there, With FX100 the Red is overall volume while (pushing the master knob) the white is the guitars signal level. This can change with different presets to match the guitars level to that of the song. Also, when streaming music make sure the volume on your device is turned up all the way. Quote Link to comment Share on other sites More sharing options...
tomshark Posted October 16, 2016 Share Posted October 16, 2016 Has anybody answered Just Startin's question I have the same problem ............ I would think that the Master Volume(upon turn On) would stay at the same level that you have it set for, when you shut the unit off For instance if it is set to 50% when you turn it off , why when you turn it back on it is reset to ~ 22% It is a problem if while your playing and for whatever reason you have to restart the pedal, lt does not return to the same level it was at prior to turning the unit off I looked through the manual and googled this, but was unable to find an answer Thanks Quote Link to comment Share on other sites More sharing options...
