imtiazax Posted February 25, 2016 Share Posted February 25, 2016 Greetz, Just wondering is it possible to record in a DAW via the USB Interface the output of a stream from an Android Device and a guitar to Firehawk via bluetooth Thanks to All Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 25, 2016 Share Posted February 25, 2016 I can't find a clear answer in the documentation but I suspect the answer is no. That's based on my expectation that the streamed audio coming into Firehawk via Bluetooth is handled in the same way that cd/MP3 audio coming into other Line 6 devices (e.g. POD HD devices) is handled. With previous devices the incoming external audio is passed directly to the analog outputs and is not converted to digital format inside the device. Hence it is unavailable to be routed over the digital USB connection. I expect Firehawk is designed the same way. Edit: Of course you can record the Firehawk-generated guitar signal to your DAW. It's the Bluetooth streaming that probably can't be passed over USB. Quote Link to comment Share on other sites More sharing options...
imtiazax Posted February 25, 2016 Author Share Posted February 25, 2016 That's a shame. No real way to record your own performance against a backing track unless you take the analogue outputs into another AD converter. Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 25, 2016 Share Posted February 25, 2016 Well, you could record or import your backing track into your DAW separately beforehand and then record your guitar in another track while the recorded backing track is playing. Quote Link to comment Share on other sites More sharing options...
