pockyway Posted March 19, 2016 Share Posted March 19, 2016 How do I run a line out to an audio interface? Can I use an a-b cable (marked "for future use")? Can I run out from the headphone jack? Quote Link to comment Share on other sites More sharing options...
Triryche Posted March 24, 2016 Share Posted March 24, 2016 You can use a standard USB cable to connect to your DAW and use the AMPLIFi as your audio interface (I'm assuming a 75 or 150 and not an FX100). Quote Link to comment Share on other sites More sharing options...
pockyway Posted March 25, 2016 Author Share Posted March 25, 2016 Thanks. My pilot guide says the usb out is for future use. Quote Link to comment Share on other sites More sharing options...
jdebiase Posted March 25, 2016 Share Posted March 25, 2016 You can use a standard USB cable to connect to your DAW and use the AMPLIFi as your audio interface (I'm assuming a 75 or 150 and not an FX100).Can you describe this process a bit more in depth? It seems you've been doing this. I have seen where people are recording directly into Garage Band for instance. What DAW and output process do you use? ThanksJim Quote Link to comment Share on other sites More sharing options...
EuanGMason Posted October 25, 2016 Share Posted October 25, 2016 I get a great line out from the Amplifi by connecting the USB output to a powered USB hub, and then attaching a Griffin iMic to the hub. The Amplifi main speaker still works and the output from the iMic is through a stereo jack and is in stereo. A Griffin iMic is essentially an external USB soundcard with analog stereo input and output and so it's very likely other USB analog to digital sound adapters will work (but I haven't tried any others). Incidentally I also attach my iPad to the powered hub (using the USB adapter that comes with the camera adapter package) and I can run Loopy saved loops through the PA for live performance. Loopy output also comes out through the iMic with this setup. Quote Link to comment Share on other sites More sharing options...
