Elvis_Parsley Posted March 19, 2016 Share Posted March 19, 2016 I play a JTV 59 with a Helix and it seems that if you use the "multi' input as suggested in the manual, you have the sound of the Variax and the magnetic pickups at the same time. Please correct me if this is not the case. It seemed a little weird when I was playing a 12 string model through a clean setting and not getting a 12 string sound that I was used to through the 500x. After setting the input to just Variax all was well. Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 19, 2016 Share Posted March 19, 2016 There must be something wrong in your settings - Multi input does not include Variax Mags. I use a JTV-59 too with a Helix and I only get the Variax Mags if I specifically select that as the input. Can you recheck things and post more detail if there's still an issue? Create a very simple preset to test - just one input, Multi, and one amp. Set the Variax model to something like Sitar which is easy to differentiate. Then change the input from Multi to Variax and then to Variax Mags. What's the result? Quote Link to comment Share on other sites More sharing options...
Elvis_Parsley Posted March 20, 2016 Author Share Posted March 20, 2016 After checking into it further, you are absolutely correct. Thank you for your help in this matter silverhead. Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 20, 2016 Share Posted March 20, 2016 You're welcome. Glad you figured it out. Quote Link to comment Share on other sites More sharing options...
