larjim Posted April 2, 2016 Share Posted April 2, 2016 Can the left (or right) 1/4" main output on the TT be used as mono? Or should I use a y-adapter to get L & R to a single plug? I see the left output on the FX100 is labeled as LEFT/MONO, but not so on the TT. I don't think the instruction manual for either of them indicates this functionality BTW. Quote Link to comment Share on other sites More sharing options...
mscroggi Posted May 26, 2016 Share Posted May 26, 2016 I too am curious about this. I found it odd that one of the 1/4 outputs is not labeled mono. Anyone? Quote Link to comment Share on other sites More sharing options...
Tcamponovo Posted June 17, 2016 Share Posted June 17, 2016 Most Line 6 products will do mono sum from the left output. The Amplifi TT however, is set up like an interface. So you will only get the left side out if you only use that. The same for the right. So for proper sound, you'll need to use both the left AND right 1/4" outputs. Quote Link to comment Share on other sites More sharing options...
yahoomedia Posted February 8, 2019 Share Posted February 8, 2019 On 6/17/2016 at 10:03 PM, Tcamponovo said: Most Line 6 products will do mono sum from the left output. The Amplifi TT however, is set up like an interface. So you will only get the left side out if you only use that. The same for the right. So for proper sound, you'll need to use both the left AND right 1/4" outputs. I’ve just recently purchased Amplifi TT ( Feb 2019) and was also puzzled as to why there was now mono out as such, Good news : It is Balanced to go into various interfaces/ inputs, I’ve plugged into a Mackie Mixer and bused directly to Logic ( Stereo) it sounds awesome. When I use AMP out it’s sound great also, but I do get lots of amp noise, depending on the Amp/FX settings and how close I am to getting interference. Direct L/R into Balanced inputs is the way to massively increase sound quality and levels, with a very low noise floor. Quote Link to comment Share on other sites More sharing options...
