Maaco1887 Posted April 9, 2016 Share Posted April 9, 2016 Any suggestions on the best sound when running into an active cab? Such as the Atomic active CLR Cab. Having problems dialing a nice tone. Newby here. Should I bypass cab sims? Quote Link to comment Share on other sites More sharing options...
spikey Posted April 9, 2016 Share Posted April 9, 2016 Change the IR's as needed, but unless you like shrill icepick tone I wouldn't run Helix or any amp processor thru an FRFR active speaker without some kind of speaker simulation. Thats what that kind of "full range flat response" (FRFR) active speaker is made for. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 9, 2016 Share Posted April 9, 2016 Any suggestions on the best sound when running into an active cab? Such as the Atomic active CLR Cab. Having problems dialing a nice tone. Newby here. Should I bypass cab sims? The first thing I would try is a high cut at anywhere between 5-8khz in either the cab sim or in an EQ block after the cab sim. You can experiment with where it sounds best for the preset you have selected. After you get the high end tamed you can start fine tuning the EQ and amp settings. Quote Link to comment Share on other sites More sharing options...
Maaco1887 Posted April 10, 2016 Author Share Posted April 10, 2016 Cutting the high end was huge. Thank you. Also added a basic eq after the amp. Very happy now. Def getting there. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 10, 2016 Share Posted April 10, 2016 Cutting the high end was huge. Thank you. Also added a basic eq after the amp. Very happy now. Def getting there. Glad to hear it! The Helix has some amazing sounds. Quote Link to comment Share on other sites More sharing options...
