JonnyPM Posted April 25, 2016 Share Posted April 25, 2016 Hi, Is there a way to set up a patch with two inputs that are different? For instance, I want the Lester 1 for path 1 and Acoustic 5 for path 2 so I can switch easier from dirt to acoustic, but whatever I set one of the Inputs to, it switches the other input also. Thanks! JPM Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 25, 2016 Share Posted April 25, 2016 I gather you are using a Variax guitar as the input. Helix can only store/set one Variax model in a preset; you can't have two models active in the same preset. You can, however, select Variax Mags as one input and Variax with a model (e.g. Acoustic-5) as the other input. If you have a JTV-59 the mags are essentially Les Paul mags. If you have a JTV-69 then the mags are more like a strat. Note that for this to work you need to be using the VDI connection from guitar to Helix. Quote Link to comment Share on other sites More sharing options...
JonnyPM Posted April 25, 2016 Author Share Posted April 25, 2016 Ok, I'll try that, I'm using a JTV89F with a VDI cable. Thanks! Quote Link to comment Share on other sites More sharing options...
