ColonelForbin Posted April 25, 2016 Share Posted April 25, 2016 https://reverb.com/item/1577618-line-6-relay-g70-guitar-wireless-system $400 Very tempting! I already have two of these, so, will pass on this.. Great wireless though! Love 'em. Cool little side note: one transmitter can transmit to two (or more) receivers simultaneously! I have one wireless set up with my Helix, the other with my stompbox pedalboard; and it's pretty cool to be able to play through two rigs at the same time without using any extra cables!!! Easy way to totally avoid noise, hum, ground loop, etc. Quote Link to comment Share on other sites More sharing options...
Tboneous Posted June 18, 2016 Share Posted June 18, 2016 Problems with dropouts with your G70? 1 Quote Link to comment Share on other sites More sharing options...
Tboneous Posted June 21, 2016 Share Posted June 21, 2016 One more time....Do you experience any dropouts with your G70? That seems to be an often reported problem. 1 Quote Link to comment Share on other sites More sharing options...
Tboneous Posted June 29, 2016 Share Posted June 29, 2016 https://reverb.com/item/1577618-line-6-relay-g70-guitar-wireless-system $400 Very tempting! I already have two of these, so, will pass on this.. Great wireless though! Love 'em. Cool little side note: one transmitter can transmit to two (or more) receivers simultaneously! I have one wireless set up with my Helix, the other with my stompbox pedalboard; and it's pretty cool to be able to play through two rigs at the same time without using any extra cables!!! Easy way to totally avoid noise, hum, ground loop, etc. Wow! Even those who simply mention the G70 drop out! Quote Link to comment Share on other sites More sharing options...
ColonelForbin Posted June 30, 2016 Author Share Posted June 30, 2016 Problems with dropouts with your G70? None; no dropout problems with either of mine! though doing the firmware update is a must-do, if it's not already up to date. Picked up a tip from the Helix Facebook user group, got these Levy's wireless holders from Sweetwater. The little metal clips that come attached to the G70 transmitters are not very robust and I tended to keep knocking them loose. http://www.sweetwater.com/store/detail/BeltpackHold Quote Link to comment Share on other sites More sharing options...
Tboneous Posted June 30, 2016 Share Posted June 30, 2016 None; no dropout problems with either of mine! though doing the firmware update is a must-do, if it's not already up to date. Picked up a tip from the Helix Facebook user group, got these Levy's wireless holders from Sweetwater. The little metal clips that come attached to the G70 transmitters are not very robust and I tended to keep knocking them loose. http://www.sweetwater.com/store/detail/BeltpackHold Thanx for the reply! You are all over this forum with in depth advice and tips. When I didn't hear from you, I got worried! Quote Link to comment Share on other sites More sharing options...
