Jasipi Posted May 4, 2016 Share Posted May 4, 2016 Hey. Not sure what the deal is with the Stomp, Modulation, Delay and Reverb switches. They trigger a different effect on each of my patches. Not sure how to assign the correct switches to the right pedals? Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 4, 2016 Share Posted May 4, 2016 Fire up HD Edit and go into the assigns and set them up there. Quote Link to comment Share on other sites More sharing options...
Jasipi Posted May 4, 2016 Author Share Posted May 4, 2016 Fire up HD Edit and go into the assigns and set them up there. Is that the only way to do it? And would i have to do this every time i create a new patch? I was hoping to be able to change the settings on the unit without connecting to a PC. Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 4, 2016 Share Posted May 4, 2016 Its how I use it to setup the patches with the FBV - HD Edit -> save. There probably is a on board assign procedure somewhere in the manual. Quote Link to comment Share on other sites More sharing options...
Jasipi Posted May 4, 2016 Author Share Posted May 4, 2016 Its how I use it to setup the patches with the FBV - HD Edit -> save. There probably is a on board assign procedure somewhere in the manual. There is indeed, i figured it out. It was explained in the HD Desktop FAQ here on Line6. If you hold the Enter button the pedal assign menu appears and you can press the foot switches and it will assign for you. I suppose it is silly to ask, but with the FBV Shortboard MKii i can only assign 4 effects to be controlled, plus wah or volume, right? Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 4, 2016 Share Posted May 4, 2016 I had to go look at the manual to make sure :) The HD Advanced Guide page 3-7 will point you in the right direction. You can assign additional blocks to a FS page B-19. Its a good manual. Quote Link to comment Share on other sites More sharing options...
Jasipi Posted May 4, 2016 Author Share Posted May 4, 2016 I had to go look at the manual to make sure :) The HD Advanced Guide page 3-7 will point you in the right direction. You can assign additional blocks to a FS page B-19. Its a good manual. I'll check it out. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 4, 2016 Share Posted May 4, 2016 Cool Dude, one tip is to make yourself some template patches with settings and assigns you normally use. Then you can load the template add what you need and save under a different name. :) Quote Link to comment Share on other sites More sharing options...
