amcevoy Posted May 4, 2016 Share Posted May 4, 2016 Firehawk 1500 arrived this morning. Very impressed. Default patches a bit eurgh, but have dialled in some nice ones of my own already. However, headphone output seems to be mono-only even when the output is wide stereo. Same headphones yield Stereo on my HD Pro X... Anyone else experienced this? 1 Quote Link to comment Share on other sites More sharing options...
jakeykim Posted May 8, 2016 Share Posted May 8, 2016 I found the same. Could this be changed by some setting? This is a stereo amplifier/FRFR. I guess Line 6 will fix this soon. Otherwise, it's a real bummer for me, as i rely so much on headphone for late-night practice... 1 Quote Link to comment Share on other sites More sharing options...
amcevoy Posted May 9, 2016 Author Share Posted May 9, 2016 Excellent, thought mine was deficient somehow. I created a request in idea scale: you can view (and vote) here: http://line6.ideascale.com/a/dtd/Stereo-out-on-headphones/820246-23508 Ta. Quote Link to comment Share on other sites More sharing options...
jakeykim Posted May 9, 2016 Share Posted May 9, 2016 Thanks! Voted. 1 Quote Link to comment Share on other sites More sharing options...
amcevoy Posted May 13, 2016 Author Share Posted May 13, 2016 Ok, just found out that you CAN run the headphone output in glorious stereo. Like you I'm a late-night-noodler and this has been a disappointment. However, if you plug an XLR cable into one of the MAIN out (doesn't need to be connected to anything else) then this flips the headphone socket from mono to stereo. Hope this helps you... 1 Quote Link to comment Share on other sites More sharing options...
jakeykim Posted May 13, 2016 Share Posted May 13, 2016 Thanks so much for the tip! It would be VERY helpful until they fix this (I cannot really figure out good reasoning behind that behavior :)). Again, thanks!! Jake Quote Link to comment Share on other sites More sharing options...
amcevoy Posted May 23, 2016 Author Share Posted May 23, 2016 OK. They've release firmware 1.20.0 and no, it doesn't fix this issue, but my amp hasn't gone silent on me since the update... Quote Link to comment Share on other sites More sharing options...
mtc10012 Posted July 12, 2016 Share Posted July 12, 2016 Is the headphone output volume independent of the amps speaker output? I'm hoping to be able to use the amp on stage and have in ear monitors hooked up to the headphone output and still have the speakers pushing for stage volume since not everyone in my band have in ears. Also does the headphone out allow you to mix in the monitor inputs like the speakers on the amp? Quote Link to comment Share on other sites More sharing options...
amcevoy Posted September 1, 2016 Author Share Posted September 1, 2016 Plugging in the headphones would switch off the speakers. I'm not sure if this is configurable or not - I've not seen any parameters for it. Ironically this is where I discovered how to get the headphones in stereo. I ended up using the XLR outs to output to a small mixing desk (Behringer 802 - £49) and in turn running the headphones from that whilst keeping the amp 'live' and a feed to FOH. Hope this helps. Quote Link to comment Share on other sites More sharing options...
