oscillateX Posted May 17, 2016 Share Posted May 17, 2016 How would one go about using the Firehawk FX in a modeling capability while taking advantage of a tube amplifier head (similar to what was done with the Spider Valve and DT25/50). Would you just use the 4-cable method through the FX Loop in a clean setting on your amp head and then use the amp/cab/effects within the Firehawk as per usual? Quote Link to comment Share on other sites More sharing options...
oddbeck Posted May 18, 2016 Share Posted May 18, 2016 Yes. If the FX LOOP isn't enabled it doesn't care about wether you're on a clean channel or not on the amp. Quote Link to comment Share on other sites More sharing options...
