POD XT Live - no USB connection and message: "this tone contains an amp or effect from an expansion pack you do not own"
Dear Line6 Experts,
I have seen countless other Line6 users report this exact same problem and sadly, I am seeing very little solutions.
I am submitting hoping that someone out there might prove me wrong and offer a definitive answer.
My POD XT Live sees very little use - I'm a bedroom warrior - and as I've seen other people on here say: one day the unit worked perfectly, then next day, inexplicably, the unit shows "Standard Model Pack Loaded" upon startup and then any patches that use an effect from FX Junkie or one of the model packs that mysteriously disappeared will show the error: "this tone contains an amp or effect from an expansion pack you do not own"
It is worth noting that I never purchased additional model packs. This thing is as it was when it came from the factory.
The REAL problem here, is that at the same time as the model packs disappearing, it seems as though the USB port on the unit has completely stopped working, and here's the troubleshooting steps I've taken to come to this conclusion:
- tried a different USB port
- tried three different USB cables
- uninstalled all Line6 software from my computer and reinstalled
- connected to two different computers and installed Line6 Monkey - still connection not recognised.
- I went back to my original computer and connected my POD HD Desktop - connection works perfectly
- Connect POD HD 500 to same USB port - connection works perfectly
- It is only on this XT Live that the USB port does not connect whatsoever. Windows doesn't even make that "USB device connected" sound when you plug it in. It is like the port is completely dead.
As you know, you can't reflash the memory without a USB connection. So that solution is out the window.
Also, deauthorising/authorising via License Manager doesn't work either because you guessed it... no USB.
I submitted a ticket with Line6 support and the conclusion was: "It seems the unit will need service.  Please contact your local distributor to arrange that. Keep in mind the cost of a repair may be near the cost of picking up a used unit."
I'm absolutely bewildered that an otherwise fully functional unit can be rendered completely useless by something so trivial.
Also, the weird coincidence of the USB connection failing at the same time that the model packs going missing almost makes me think that a case of planned obsolescence is going on here - but I don't want to be that pessimistic just yet.
Considering the vast number of other people I see experiencing this issue and submitting questions to the forums, is this a known issue that Line6 are working on?
As you can probably tell I'm a Line6 enthusiast and own a vast array of their products (XT, HD Desktop, HD 500, Variax 300, JTV-59, DT25 Combo - the Pod XT Live holds a special place in my heart, though) but I must say this hardware issue and subsequent "support experience" has really soured my enthusiasm for their gear. Please work with me here to offer some suggestions before I ragequit and sell all my Line6 stuff on eBay for $50 and pickup playing the drums, instead.
...No one wants that.
Joe
It is worth noting as well that the only thing I haven't tried yet is the MIDI cable connection. I don't own a MIDI to USB cable but from what I've read, it doesn't sound like people get very far with that method, either? Let me know your thoughts.
Stuff breaks my man and life goes on. You can get another XTL for under $100 and the Bean for less. The midi USB cable is ~ $30 +/- who knows if that will work it might as it was used for firmware flashing on the first XTLs to enable the USB. Check the port for bent pins or missing center block btw.
Your biggest problem would be the model pack not showing as it might actually be indicating a bigger problem - memory (but just guessing).
-B
BillBee,
Firstly: thank you very much for your prompt and courteous reply. I see you responding to many people on here and I hope you get the gratitude you deserve.
In response to your suggestion of checking the USB connection pins - do you have a guide handy on how to open the unit up correctly? I just made a brief attempt but there's screws all over the place and I'm not sure what I'm doing.
Also: where would a luddite like myself find the "missing center block"?
How do you know all this stuff? Lololol (considering you're not a Line6 employee?)
Cheers again,
Joe
Hey Thanks my man,
I am like yourself - I had problems and came here and lots of great people helped so just paying back as I can. Things do break over time - my X3L, XT Pro and others but in all honesty I have had a Zoom G9 barf, Digitech RPs crap. But like yourself I have a shelf of other L6 gear that keeps going. Its one reason I like the Beans - I edit on the PC (saves the knobs and buttons) and the FBVs are cheaper to replace and/or fix.
You don't need to take the XTL apart - just put it on your lap and grab a flashlight. Shine it in the usb port and you should see the wires that the cable should hit when plugged in. In the middle of the port there is a wee little plastic block (your HD has it too) the block keeps things aligned and centered. As you have guessed - if things don't line up then its not going to work.
Now if that part is bad its a part that should not break the $$ point of fix/replace and yep there are a lollipop load of screws. But man its a toughie to throw $ at something where there might be a bigger issue looming.
I do feel your pain and if you try the MAudio usb/midi cable to flash be sure to try in/in and out/out as that cable seems to work that way for me (vs the out/in, in/out which is usual).
BTW the Metal Pack for the HD does justice to the XT/X3 models \m/ Big Bottom Amp \m/
-B
