Changing Split Routes while changing channels
sheehanje
I'm working on a ABY Split route so I can add certain effects to a clean channel.
I'm using an external amplifier, and have Midi CC assigned to 3 footswitches to change channels on my amp (sending it to an external relay box, mini amp gizmo).
My issue is I can get turn on the split route when changing to my clean channel because I have them merged to the same footswitch, but how to I get it to turn off when I change back to my other channels without hitting more than one button?
I've thought about using a gain block for this, but it seems like a messy solution.
Also, is there a way to turn on/off part of the path using the footswitch - so Path 2b gets turned on with one footswitch and turned off with another - that would work for me too.
Not sure if I am correctly understanding the question, however here is a thread with a link to a video that I found useful for using a self-assigned FS for switching paths back and forth
http://line6.com/support/topic/20966-helix-patch-2-activation/
Dennis
Dennis
Not quite what I'm looking for seeing I'm using an external amp.
Basically I want this:
I hit footswitch 9 - it sends Midi CC#88 to change the channel on my amp to Channel one, and at the same time I want it to turn on a split to path 2B to pickup effects I have there for my clean channel
That I can actually do, but the problem is I have to hit the same footswitch to turn off the split route.   Instead I would like to:
Hit fooswitch 10 -  it send Midi CC#90 to change the channel on my amp to channel three, and at the same time I want it to turn off the split to path 2B to remove the effects I have there for my clean channel
I am afraid not.  You need to vote for "scene mode" in Ideascale.
