TayK47tv Posted June 25, 2016 Share Posted June 25, 2016 Hi, I have a UX2 with Audio Technica AT2020 Condenser mic connected. The mic is receiving power and when I open Pod Farm I can see that it is picking up up my voice. The needles on the UX2 move as well as the levels in Pod Farm, but I cannot hear my voice, nor can anyone in any of the application I try to use. My input is set to mic 1, and my default audio recording device is set to the UX2 in Windows. What am I doing wrong? Why am I unable to hear myself? Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 25, 2016 Share Posted June 25, 2016 You need to connect your speakers to the UX2 outputs. Quote Link to comment Share on other sites More sharing options...
CC51 Posted July 24, 2016 Share Posted July 24, 2016 once you have the mic and needles moving you need to select the UX2 in your DAW. You have the Mic 1 selected so thats good. so you go to the pull down menu in Input slection and there should be a selection of choices. The UX2 should be seen in the DAW software ASIO etc, and the correct sound card should be selected. Also in Windows sometimes there is a conflict of the UX2 or your stock soundcard...so DISABLE the stock sound card. and select the UX2. there is also a Preference pull down in Gearbox/Pod Farm, so you need to check that and make sure its not muted. thats a few things to check. Quote Link to comment Share on other sites More sharing options...
