jeebster Posted June 26, 2016 Share Posted June 26, 2016 Hey Everyone, I'm using Helix as my recording interface. My DAW allows for changing the output channels of the metronome and I'd like to take advantage of this routing to send the click to the headphones and the remaining audio to output channels 1 and 2 for my monitors. Is this possible? Any help would be appreciated, cheers. Quote Link to comment Share on other sites More sharing options...
jeebster Posted August 1, 2016 Author Share Posted August 1, 2016 long time bump...is this possible or do I need to create an aggregate device? Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 1, 2016 Share Posted August 1, 2016 Try this setup: - create a dual path preset in Helix. Use Path 1 for your guitar processing. Use Path 2 for your headphone signal. - in your DAW send your headphone/click track to USB 3/4. Set the Helix preset Path 2 input to USB3/4 - connect your Helix XLR L/R outputs to your monitors. Set your Path 1 outputs to XLR only. - connect your headphones (you'll need an adapter) to the Helix 1/4" outputs. Set your Path 2 outputs to 1/4" only. Set the 1/4" output signal level to Mic, not quite what your headphones are expecting but not as loud as Line level. Start with a very low output level on the Path 2 output (set output level parameter to -max Db) to protect your ears and headphones. Increase slowly until adequate. Quote Link to comment Share on other sites More sharing options...
