FarleyUK Posted July 9, 2016 Share Posted July 9, 2016 Hi guys, Played a gig last night and it appeared that I was getting a load of feedback from the amp that I never normally got. I'm not using a distortion block, running 4CM, and have the SR block set at 100% mix and 0db. It seems ok without the Helix - is there anything that could be adding to the feedback from within the Helix? Quote Link to comment Share on other sites More sharing options...
ricksteruk Posted July 9, 2016 Share Posted July 9, 2016 Maybe are you using a compressor in helix? that might cause early feedback. Also in 4cm it's worth remembering that Helix's Send/Return sockets should be set to "Instrument" - not Line - or you'll be feeding way to much signal in to the front of your amp... But of course your amp's FX loop is either running at -10dBV consumer line level or "pro" +4dBU level - which means that it will be sending a very hot signal level back into Helix if set at Instrument. I always turn down the Return level on my Send/Return block to about -15dB when using my amp in 4cm with its FX loop at -10bBV Quote Link to comment Share on other sites More sharing options...
pilottes Posted July 9, 2016 Share Posted July 9, 2016 I always turn down the Return level on my Send/Return block to about -15dB when using my amp in 4cm with its FX loop at -10bBV Interesting! My JVM is also set at -10dBV. Would'nt be best to simply set the send/return at Line in the Global Settings for 4CM config? Quote Link to comment Share on other sites More sharing options...
ricksteruk Posted July 10, 2016 Share Posted July 10, 2016 Interesting! My JVM is also set at -10dBV. Would'nt be best to simply set the send/return at Line in the Global Settings for 4CM config? That would seem to make sense - but then you would be SENDing Line level into your JVM's Guitar input.. way too much signal level! You really need to use an Instrument Level SEND on Helix and a Line level RETURN... but you can only select the same for each pair of Send/Return 1 Quote Link to comment Share on other sites More sharing options...
pilottes Posted July 10, 2016 Share Posted July 10, 2016 That would seem to make sense - but then you would be SENDing Line level into your JVM's Guitar input.. way too much signal level! You really need to use an Instrument Level SEND on Helix and a Line level RETURN... but you can only select the same for each pair of Send/Return Alright I'll include this in my settup. Thanks Quote Link to comment Share on other sites More sharing options...
FarleyUK Posted July 11, 2016 Author Share Posted July 11, 2016 Yep, got the S/R set to instrument, so it isn't that. Seemed to be much better on the Saturday gig, although no idea why.... I was closer to the amp and cab as well. No compressor in use. Quote Link to comment Share on other sites More sharing options...
