jaymo99 Posted July 12, 2016 Share Posted July 12, 2016 some years ago , I bought a line 6 pod (the original updated to 2.1) It did not come with a power supply so I went to a music shopped bought a replacement everything seemed ok... FF to a couple weeks ago I bought a POD XT and FBV shortboard MK1the power supply that came with the PODxt looked rather old so i Used the new on I just bought. all was fine until i plunged in a Telecaster I had just bought and BOOM the 50 hrz hum from hell. thinking it was just because of unshielded single coil pick ups. i did a cavity shielding and new silver braided wiring it became drastically better accept no all i hear in ver specific hum turns out its coming from the transformer for the pod. and it is almost too hot to touch.So im thinking maybe its going bad hence the noise... i did some searching and learned the standard power supply for Pod xt is a PG2 power adapter. on the power supply there is no PX-2/PX-2g AC but Model #11-32-0020. and it gets VERY hotmy question is the Line6 Model #11-32-0020 transformer the same as the Line6 PX-2/PX-2g AC or is it better i buy a PX-2/PX-2g AC?Thanks for any advice Jaymo Quote Link to comment Share on other sites More sharing options...
BillBee Posted July 12, 2016 Share Posted July 12, 2016 My XT uses the PX-2/2g. 9v AC 2000 ma. I can't comment on the other one but it should list the specs. If it matches the above it "might" be one of the early adaptors. But it shouldn't get super hot. Quote Link to comment Share on other sites More sharing options...
AParedes Posted August 30, 2016 Share Posted August 30, 2016 +1 to BillBee. The #11-32-0020 definitely sounds legit, but the requirement is 9V AC 2000ma. the "G" (for "green") in the PX2 came later (2008?), as there were environmental requirements in the US that necessitated changing a few components. Early PX2 units were 1200ma (i.e. original POD and DL4), so you MAY have received this by someone who didn't know (or look closely at the specs). In any case, I recommend you try the PX2G, and it that works better (and cooler) just use that moving forward. Quote Link to comment Share on other sites More sharing options...
