trolley Posted July 12, 2016 Share Posted July 12, 2016 I've just acquired a used G90 & TBP12. I've only had a quick play in the house (used to use a G30 live). It all works, but... 1) Both units only show 12 channels 2) When I switch on the TBP 12 I don't see any RF values 3) When I press Select & then Value I get the channel number. And that's it! If I let go of Select it carries on displaying the channel selected & nothing else. I can happily select any of the 12 channels available Since it all works I'm not overly worried, but I'm a nosey bugger & don't like not knowing everything that's going on & not being able to select it all - even if I don't want to use it. If I switch it on & hold down the select button it displays V1.02 Any ideas? Quote Link to comment Share on other sites More sharing options...
ilynnathaniel Posted August 17, 2016 Share Posted August 17, 2016 I have bought a line 6 G90 and the issue i am having is with transmitter that came with it. When ever i move it SHUTS OFF!? The unit was new out of the box worked great for a few months. But now if i move it shuts off then i have to tap it and the power comes back on but the second i move it shuts off again? I tested the batteries and put brand new ones in and that not it. So its killing my live shows because i have to stand perfectly still. Which kind of voids out the reason of having a wireless. Anyone have any suggestions? Quote Link to comment Share on other sites More sharing options...
AParedes Posted September 1, 2016 Share Posted September 1, 2016 Trolley - sounds like you have firmware prior to the "RF2" release. you need an XDV 75 to update if you want the latest, but most Line 6 repair shops offer this upgrade service as well. personally I like running the latest software in RF1, as it uses four carrier waves (rather than two for RF2) - the product specialists sometimes call this the "kill em all mode". Ilynnnathaniel - sounds like there may be an issue with your TBP12 pack, try a different pack to see if you have the same situation. All Relay or XDV TPB6 & 12 transmitters are interchangeable (assuming you have recent software). I suspect that the battery door may be coming slightly ajar when you move, which is powering the unit off - but please confirm with another transmitter. if you purchased the unit new you should connect with your Line 6 distributor to look into a warranty repair. Quote Link to comment Share on other sites More sharing options...
