hyperviolet Posted August 22, 2013 Share Posted August 22, 2013 I have a POD X3 bean and I've set it up to use dual tone and in the output options I've panned tone 1 to the left and tone 2 to the right. Why is it this only works when I have both output cables plugged in? When I unplug either left or right, I get both tones through one output. I'm using a 1/4" to rca phono cable which plugs into a power amp if that helps. Quote Link to comment Share on other sites More sharing options...
BigChas52 Posted August 22, 2013 Share Posted August 22, 2013 I know that the X3 sums both left and right to the left output if you unplug the right. I didn't know it worked the other way around as well. Quote Link to comment Share on other sites More sharing options...
db0451 Posted September 12, 2013 Share Posted September 12, 2013 Yes, both mono quarter-inch outputs are mono-capable, so if they are the only one with a cable plugged in, the X3 will sum both stereo channels to that single mono output. The manual states this clearly. Quote Link to comment Share on other sites More sharing options...
