bruce1955 Posted August 4, 2016 Share Posted August 4, 2016 Is it possible to assign amp models to FS 1 through 4 and assign effects to FS 5 through 8. So far I have found the HD500 not very user friendly!!! Thanks, Bruce Quote Link to comment Share on other sites More sharing options...
Metalal5150 Posted August 4, 2016 Share Posted August 4, 2016 Hi Bruce . Course it can ! This is the beauty of HD500 over the Rack units !!! ---All copied from Advanced guide for HD500 ---LINK here-- http://l6c-acdn.line6.net/data/6/0a06434dfb244f7b7f489af64/application/pdf/POD%20HD500%20Advanced%20Guide%20v2.0%20(%20Rev%20A%20).pdf FX & Amp Block Footswitch Assignment Each of the FS1 through FS8 footswitches, as well as the Exp Pedal’s “Toe Switch†can be configured to toggle any of the FX or Amp Blocks On/Off. You can reference the current Preset’s FX footswitch assignments by pressing the VIEW button to display the Performance View screen. The assignments for FS1-FS8 will differ depending on your current Setup - FS Mode setting (see “Page 1, Setup:Utilities Options†on page 2•2): FX assignment for FS1-FS8 ABCD assignment for FS5-FS8 Features & Functionality 3•11 Note that when Looper Mode is active, the Performance View displays a set of Looperspecific footswitch functions, as covered in “Looper Footswitch Controls & Performance View†on page 8•1. Assigning an FX or Amp Block to a Footswitch From the Signal Flow View, select the FX or Amp Block that you want assigned to one of your footswitches. As an example, we’ll select the Delay FX Block. Then Press and hold the ENTER button to display the Footswitch Assign screen. ENTER DBL PRESS TO ASSIGN CTL MOVE AMP & FX ON / OFF Select the desired Amp or FX block, then press and hold the ENTER button The Footswitch Assign screen, with a Delay FX Model selected Features & Functionality 3•12 Use Multi-function Knob 1 to select the footswitch to which you want this FX Block assigned - choose FS1 through FS8, the EXP Toe Switch, or None to remove the Block’s assignment. The following behaviors apply: • If a footswitch already has an FX or Amp block assigned: The existing Block remains assigned, and selecting this footswitch additionally assigns your new Block. When referencing the Performance View, you’ll see the footswitch display a “Multi†graphic to indicate this. You can configure 2 or more parameters to the same footswitch to toggle them On/Off simultaneously - or, have one toggle On while another Toggles Off! Indicates multiple Blocks assigned to a footswitch TIP: To reference current footswitch assignments, when in the Footswitch Assign screen, use the Nav. Disc buttons to select each Block, and look at the Knob 1 setting for each at the bottom of the screen. • When a footswitch has no Block assigned: You’ll see the N/A graphic displayed in the Performance View for the respective footswitch. Indicates no Blocks assigned to a footswitch Features Hope this helps !!! And try using the PC Editor for the easiest possible way to configure this VERY POWERFUL UNIT! RESPECT!! Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted August 4, 2016 Share Posted August 4, 2016 Just to clarify ----- NO, you can't assign amp models to footpedals. But, yes, you can assign amp models to footpedals. You can only have 2 amp models. You cannot have 4, and then switch between them. Quote Link to comment Share on other sites More sharing options...
