bc05 Posted August 14, 2016 Share Posted August 14, 2016 Hi all Working on getting the best sound for my Washburn Acoustic (NOT mic'd up) by plugging directly into Helix. There is a 1/4 inch output on the guitar AND an XLR Which is the best approach do you think? At the moment Im going in like a regular guitar and then blending the DI'd sound with some Taylor IR's I found on here in the Torpedo Wall Of Sound Plugin inside Cubase Also - I find the level of the acoustic quite low on the dry USB 7 channel I record - is it best just to "Normalise" this up after it's recorded? Or can I make the dry track hotter on the way in? Many thanks! Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted August 14, 2016 Share Posted August 14, 2016 Seems to me you have the guitar correctly set up. Some folks use the AUX IN on the Helix. As for USB 7 level, I believe the main intent for line 6 was reamping. You are getting the actual instrument level. ie, on my electric I get around - 18 to -20 db on the level. playing it back reamping gives the helix the original guitar level. if you want to use it in a mix, then you do need to boost the level to line. Quote Link to comment Share on other sites More sharing options...
RRMark Posted August 15, 2016 Share Posted August 15, 2016 Also - I find the level of the acoustic quite low on the dry USB 7 channel I record - is it best just to "Normalise" this up after it's recorded? Or can I make the dry track hotter on the way in? Many thanks! Recording level of -18dB is about righthttp://www.soundonsound.com/sound-advice/q-how-much-headroom-should-i-leave-24-bit-recording Quote Link to comment Share on other sites More sharing options...
ColonelForbin Posted August 16, 2016 Share Posted August 16, 2016 you could use the AUX in and assign it to USB8; compare that to USB7, see if it makes any difference in tone or recording level Quote Link to comment Share on other sites More sharing options...
