Sign in to follow this
A_mattison
Firehawk FX 4 cable method
Can you turn the pre-amp modeling on and off on the Firhawk FX using the 4 cable method so that you could take advantage of your actual amp preamp if you wanted to, or bypass it and use an amp modeler in the Firehawk? (Like you can in the hd500x?)
Yes, the 4CM method will work with Firehawk FX just like it does with the Hd500.
