bwurster Posted September 16, 2016 Share Posted September 16, 2016 I use a MIDI CC Toggle assigned to a footswitch to control an external effect. Sometimes, when interacting with the switch, it switches the unit display from "Home" view to the command center view. I am at home and playing in my socks (touch issue from resting foot on switch??) I don't know what causes it to happen, does anyone know why this occurs and how to prevent it? Thanks! Quote Link to comment Share on other sites More sharing options...
tagmusenmagnus1 Posted September 16, 2016 Share Posted September 16, 2016 Well. you have the answer yourself. If your socks are just a little bit sweaty, they won't insulate and therefore the touch-capabilities strikes.. Quote Link to comment Share on other sites More sharing options...
bwurster Posted September 16, 2016 Author Share Posted September 16, 2016 Yeah, I kinda thought that, but I can't seem to intentionally transition from the home view to the command center view by just touching the switches. Is there some magic knock? or a way to disable it? Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted September 16, 2016 Share Posted September 16, 2016 Yeah, I kinda thought that, but I can't seem to intentionally transition from the home view to the command center view by just touching the switches. Is there some magic knock? or a way to disable it? You can disable the cap-sensitive switching by setting the "Touch Select" parameter to "Off" under Global Settings --> Footswitches. Quote Link to comment Share on other sites More sharing options...
