gk001 Posted September 16, 2016 Share Posted September 16, 2016 Hi All For info, if anyone's contemplating upgrading Both my iPad Air & iPhone 5s are working fine with Sonic Port VX and iOS 10 Tested with the following with no issues Mobile POD Garageband Cubasis Polytune 4Track Sonoma Guitar Tone Music Memos Skype Will test with iPhone 7 and update as soon as it arrives... Quote Link to comment Share on other sites More sharing options...
gk001 Posted September 26, 2016 Author Share Posted September 26, 2016 Update Sonic Port VX is working with no issues on iPhone 7 and above Apps Quote Link to comment Share on other sites More sharing options...
Bipai Posted October 12, 2016 Share Posted October 12, 2016 Hi! I just bought my Sonic Port VX, and as soon I got home I've plugged it in my iPhone 6s with iOS 10.0.2, and it just didn't work!!!... The iPhone couldn't even find the hardware when I've opened Mobile POD app!!! On my MacBook it seems to work. But I bought it to use with the iPhone primarily and can't make it work!!! Does anyone can help me? Anyone with a solution? (I'm sorry for my rough english) Quote Link to comment Share on other sites More sharing options...
alldre58 Posted November 28, 2016 Share Posted November 28, 2016 I'm having the same problem. Worked literally once on my iPhone 6 and now says "hardware not supported" what the hell, these are still for sale everywhere...shouldn't really be on the market if they are already obsolete surely? Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 28, 2016 Share Posted November 28, 2016 My Sonic Port VX works fine on my iPhone 6. I am running iOS v10.1.1. My Mobile Pod app is v2.0.2. Maybe update your software? Quote Link to comment Share on other sites More sharing options...
jhlui1 Posted December 21, 2016 Share Posted December 21, 2016 My 2nd unit Sonicport VX (purchasing via Line6's refurb program) works fine with IOS 10.2 on an iPhone SE. That being said, the 1st unit I received actually was pretty much the same thing @Bipai described - was okay working via USB, but the Lightning port (or 30-pin, because I also tested it with an older iPod Touch and iPad 2) was completely non-functional. In basic testing, I noticed if you are just supplying USB power to the Sonicport without connecting to either an iPhone, nor an actual PC/Mac, the unit won't show any signs of working (you can plug in a headset, but you won't hear anything.) Until it is recognized as an ASIO device on a PC, it will not enable even the direct-monitoring switch. Or if you then plug it into an Apple device (Lightning or 30-pin) with a compatible App running (important, because if you aren't actually running a compatible App while trying to use the Sonicport, it will similarly appear completely dead. (and per my prior finding, if you try to connect the Lightning AND the USB simultaneously, the USB side will be disabled for playback/recording (meaning the PC/Mac will not detect the device, and won't enable it until you disconnect the Apple device.) Make sure you at least download and run the Line6 Mobile POD (you don't have to pay for the App - leave it in Trial Mode.) After a few minutes (took me about 5) of being connected to the Sonicport, the Mobile POD App will unlock itself and all the preset tones should unlock - but it doesn't happen instantly upon the first plug-in. Before the App fully unlocked, my Sonicport initially appeared non-responsive on the Apple device, as well. Then after a minute or two, I saw the device show up in the Settings screen of the App. And a few more minutes later, all of the lock icons disappeared (you may need to be connected to the Internet for this to happen, whether cellular or WiFi.) Quote Link to comment Share on other sites More sharing options...
