Ruben40 Posted September 21, 2016 Share Posted September 21, 2016 I'm using a Telecaster Deluxe with the wireless G30 receiver into Helix guitar input. Should I switch on the pad option in the Helix or should I leave it off.What's the maximum level of the g30 receiver ?Can it overdrive the guitar input ? Thanks for help Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 23, 2016 Share Posted September 23, 2016 I would set the input pad based on the output of the guitar you're using. In other words, if you would turn the pad on while connected with a cable, turn it on while using the G30. The G30's output will vary based on whatever signal it's getting from the guitar. As far as the clipping the Helix's input, it's not so much that as much as it is not sending too hot of a signal into the amp models and other effects. The Helix has 123dB of dynamic range, so it's going to take quite a hot signal to actually clip the input. Quote Link to comment Share on other sites More sharing options...
