thsocom41 Posted October 12, 2016 Share Posted October 12, 2016 Hey guys. 10 years of experience with line 6 pods and just got the helix this week. I have a question about how to pan dual cabinets to be centered instead of left and right because at the venue I play in, we don't run stereo, but I'd still like to use the option to have a different tone by panning two cabinets to the center. What do I do to make this happen? Thanks Quote Link to comment Share on other sites More sharing options...
phil_m Posted October 12, 2016 Share Posted October 12, 2016 If you're only using one of the 1/4" or XLR outputs, everything will sum automatically through that output. If you want to hear things in dual mono rather than true stereo through the headphone output, just put a mono Gain block after the dual cab block. That will sum it's output to mono. Quote Link to comment Share on other sites More sharing options...
willjrock Posted October 12, 2016 Share Posted October 12, 2016 What do I do to make this happen? Use two cab blocks. choose the single option each time you add a cab.. Split them into 2 paths. Where the paths come back together, after the cabs, click right on the merge point and drag that down. This creates a separate out for each cab. Click on the output blocks(the arrows) and pan to taste. Quote Link to comment Share on other sites More sharing options...
thsocom41 Posted October 13, 2016 Author Share Posted October 13, 2016 Ok thanks guys, I'll give it a shot after work today. Quote Link to comment Share on other sites More sharing options...
