zrkrlk Posted November 23, 2016 Share Posted November 23, 2016 Hi , I changed my neck and middle pickup with emg hz s1 and i got very bad second (bridge+middle) position....phase poroblem... So i resolder my factory bridge humbucker, i changed his phase and i got briliant straty sound... New problem--- pickoups pulling strings out of tune in low position... I am consulted some luthier and they told me i can try to return bridge pickup in original wiring, and to change phase on my two emg single ciols...I did it and then the main problem occurs - single coils don wont to work when phase is changed !?! Does somebody know explanation for this situation? Factory bridge work fine in boath case , but two singles work only when they are soldered like on shematic +/+ and -/- Also, is it possible to solve a problem of pulling strings out of the tune on this vay? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted November 23, 2016 Share Posted November 23, 2016 Also, is it possible to solve a problem of pulling strings out of the tune on this vay? If the pickup is pulling strings out of tune, then it's simply too close to the strings. It has nothing to do with how you have it wired. The magnet strength is what it is, and doesn't change no matter how you wire it up. Some are stronger than others... Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted November 23, 2016 Share Posted November 23, 2016 Yup - too close to the strings. Quote Link to comment Share on other sites More sharing options...
zrkrlk Posted November 23, 2016 Author Share Posted November 23, 2016 If the pickup is pulling strings out of tune, then it's simply too close to the strings. It has nothing to do with how you have it wired. The magnet strength is what it is, and doesn't change no matter how you wire it up. Some are stronger than others... Yup - too close to the strings. Ok, i agree with you, and i can find compromise height of pickups... I have more then ten guitars with diferent pikoups ( emg sa, 81, 85, 89, gibson, dimarzio at, pro track, seimour duncan....) and i never had problem with pulling strings, ...anyway I found a compromise height and this is ok. I still can't understand why my two singles don't work at all when phase is changed?? Quote Link to comment Share on other sites More sharing options...
