squirrel211 Posted November 30, 2016 Share Posted November 30, 2016 I have tried before to use the M13 as a dual mono box, and it didn't work for the R Input. Set up was: Guitar --> ABY --> A/Amp1 --> FX Send --> L Input M13 --> L Output M13 --> FX Return --> B/Amp2 --> FX Send --> R Input M13 --> R Output M13 --> FX Return Amp1 worked, and also supplied effect to Amp 2 when used. Amp2 didn't work at all. Can I run a second ABY box, after the FX Sends from both amps, into the L Input of the M13 and leave the ABY box in the Y setting, assuming both amps' FX signals would be summed to the L Input on the M13? I want to use 2 amps, basically as a glorified channel switcher, and have the M13 in the loops of both simultaneously. Quote Link to comment Share on other sites More sharing options...
squirrel211 Posted December 6, 2016 Author Share Posted December 6, 2016 UPDATE: Using an ABC switcher, I have summed both FX Sends to mono, using both outputs from the m13 to go back to both amps. Doesn't work as well as I had hoped, the effects are much louder in one amp, despite that amp being the clean amp. Looks like I'll be buying 2 M9's and running 1 in each amp, for delays.... Quote Link to comment Share on other sites More sharing options...
Foggy1 Posted January 30, 2017 Share Posted January 30, 2017 i have a M13 using the 4 cable method that i used a Tone Bone ABY and ran it into my EVH head along with a small Crate Palomino amp--did you have any problems getting the effects to work with the PreAll setting for the loop? when i use the Pre setting none of the effects work in the loop--i have to set everything to postall Quote Link to comment Share on other sites More sharing options...
squirrel211 Posted January 30, 2017 Author Share Posted January 30, 2017 I'm uncertain what you're asking me Foggy? I'm using the 2 cable method of just running my amps' fx loop sends into the inputs of the M13, and running the outputs of the M13 back to the corresponding amp's fx return. I use the M13 for modulations/Filters/Reverbs/Delays with already overdriven amps, so I only want to have it in the loop of each amp. EXAMPLE: Amp 1 input ---- Amp 1 FX Send into M13 Left Input // M13 Left Output into Amp 1 FX Return Guitar into ABY into: Amp 2 input ---- Amp 2 FX Send into M13 Right Input // M13 Right Output into Amp 2 FX Return Quote Link to comment Share on other sites More sharing options...
squirrel211 Posted January 31, 2017 Author Share Posted January 31, 2017 UPDATE: I was using Analog Chorus to test the functionality of using the fx loop of 2 amps, while switching my guitar from 1 amp to the other with an ABY box. * Most of the delays behave EXACTLY AS I WISHED! The chorus is a totally different story; the wrong amp would be the only one with sound coming out at one point... Basically, any patch/effect that is true stereo will work. Quote Link to comment Share on other sites More sharing options...
