Stereo?
Philmacrakken
It may be the placement order of your FX. Many FX are mono and they always output a mono signal, even if a stereo signal is fed into them. So if your signal chain has a mono FX after a stereo FX you will not hear stereo.
To test this create a preset that has only an amp (which is mono) and a stereo delay FX following the amp. Configure the delay so that the stereo effect should be obvious. Listen using headphones in the Firehawk. Make sure your headphones are properly connected and that you can hear stereo using those headphones in another device (e.g. Your home stereo system). If you hear the stereo from Firehawk in this situation then your problem is FX ordering. If you don't hear stereo then there may be a problem with your Firehawk.
