Sign in to follow this
Guest zepdude
Tap tempo not working
Guest zepdude
Guys... I have been  a line six user sine day one.. but really the tap temp wont work on the spider v... unless you set the ms to 1/4 notes?????  took my a while to figure it out .....why cant you give us a manual to tell us this??? Cmon we deserve a advance guide.. cheesy pilot guide.. thats all we get??
Yes, for the delay time (or whatever parameter) to be synced to tap tempo it has to be set to a note value (not limited to just 1/4 notes).
Which is really good is you use stereo fx! I like having the note value vs tap a tempo speed. I can see where it can cause confusion though. Many higher end units use note value on delys taps too.
My point is... I had to figure it out.. nowhere is a manual that tells me this.... if so... it's so hidden that I can't find it...
Sooo...  if was in a manual... I would be happy... but thinking something is wrong w/ my amp for an hour... waste of time.. all edit software from flextone an up had a  control for tap tempo on or off... that makes more sense..
