hanyk16 Posted January 20, 2017 Share Posted January 20, 2017 Hallo, I´ve a problem with the distortion-volume in contrast with other clean effects... I play the line 6 amplifierTT through my external-soundcard by using the mainoutputs of the TT. My speakers are on highest volume like soundcard and the TT. But if I use an distortioneffect mostly without reverb-effect it is always too quiet and it sucks! If I want to pull it louder it starts to scratch like an overdirve but the level in my soundprogramm is not really high like it is when I use clean-effects which are mostly loud enough and not causing any problems. Is there any trick or advice to use dry distortions and level them up without having those "scratches"?! I´ve already tried it by using eq and reducing the low frequences, also in the "amp/cab". But it isn´t good enough! I want to play clean and distortion on a same level (likeeverybody wants) but it shouldn´t be that quiet that I can still hear the strings... thx for any helpful replies greets Quote Link to comment Share on other sites More sharing options...
hanyk16 Posted April 18, 2017 Author Share Posted April 18, 2017 Ah thanks for the helpful replies! :/ Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 18, 2017 Share Posted April 18, 2017 You're running the TT main outs into another interface? If so, what interface? Also, each amp model should have a volume control that should not affect the model's tone. Quote Link to comment Share on other sites More sharing options...
hanyk16 Posted April 24, 2017 Author Share Posted April 24, 2017 You're running the TT main outs into another interface? If so, what interface? Also, each amp model should have a volume control that should not affect the model's tone. Hello! thx for your reply! yes it does have it´s own volume control (focusrite saffire 6)! but that´s not the way I want my sounds to play (always have to switch the volume!) As I already wrote on my first post: "I want to play clean and distortion on a same level (likeeverybody wants) but it shouldn´t be that quiet that I can still hear the strings..." The Problem I still have, ist that my speakers begin to scratch, if the distortion is loud enough...in but if I switch to clean it´s ok (without any scratches) Now I can reduce the volume, but that is so low, that it doesn´t make any fun to play! Just wanna know if there is any trick for this, or do I need stronger speakers for this? Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 24, 2017 Share Posted April 24, 2017 What speakers are you using? Quote Link to comment Share on other sites More sharing options...
