BowerR64 Posted March 7, 2017 Share Posted March 7, 2017 Is there a mode that you can put the amp in so that if the knobs vibrate from extreme levels the settings dont change from the vibration? example: Your on a patch with the gain at say 80% but the patch you were on was a more rock crunch sound and you had the gain knob at 30% so the dial is at 9:00 You crank up the 80% gain patch and this vibrates the amp enough to move the gain knob which is actually at 9:00 and your heavy gain patch now drops to 30% Quote Link to comment Share on other sites More sharing options...
ADBrown Posted March 7, 2017 Share Posted March 7, 2017 I don't believe there is a way to lock in a parameter so moving the knob would have no effect. Which model Spider V are you using? The knobs moving from vibrations from the volume coming from the amp really shouldn't be happening. Quote Link to comment Share on other sites More sharing options...
BillBee Posted March 7, 2017 Share Posted March 7, 2017 I don't have Spider V but on the Pods parking the knobs helps with that issue. Parking means setting the knobs to 0 then turning the amp on - not the master vol though. Hopefully its the same on the new Spiders. Quote Link to comment Share on other sites More sharing options...
guitardad123 Posted March 7, 2017 Share Posted March 7, 2017 I don't believe there is a way to lock in a parameter so moving the knob would have no effect. Which model Spider V are you using? The knobs moving from vibrations from the volume coming from the amp really shouldn't be happening. That would only happen with a defective rotary encoder. Quote Link to comment Share on other sites More sharing options...
