Gepcat Posted March 17, 2017 Share Posted March 17, 2017 When I change presets, my mix controller is at a high level, would like it to be at zero or minimum.... For instance, I will set a mix controller for the delay let's say 0-30%. Every time I go back to that preset the delay is full on. I would like it to be at minimum ... Is there a way to set that? Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 17, 2017 Share Posted March 17, 2017 If you're saying you have the mix for the delay tied to an expression pedal, yes there is a way to do that. In Global Settings > EXP Pedals, knobs 4, 5, and 6 let you set how the expression pedals behave. You can choose Per Snapshot, Per Preset, or Global. You'd want to set that to Per Snapshot or Per Preset for the pedal you have the parameter tied to. Then when you go to the preset, the value of the mix parameter will be set at whatever it was when you saved the preset. Quote Link to comment Share on other sites More sharing options...
Gepcat Posted March 17, 2017 Author Share Posted March 17, 2017 Where the value is already set to 0-30% , by doing this it would automatically be at 0 when I open the preset? Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 17, 2017 Share Posted March 17, 2017 Where the value is already set to 0-30% , by doing this it would automatically be at 0 when I open the preset?Yes, as long as it was at zero when you saved the preset. It would only change when you move the pedal. Quote Link to comment Share on other sites More sharing options...
Gepcat Posted March 17, 2017 Author Share Posted March 17, 2017 Thank you.... I will try that Quote Link to comment Share on other sites More sharing options...
