Indianrock2020 Posted March 20, 2017 Share Posted March 20, 2017 This has probably been covered but I've been considering something like the Wampler Paisley pedal for the 500x's effects loop. What have your experiences been trying something like that? I can get overdrive/amp mic/cab combinations I'm quite happy with using built-in stuff, but it is a bit of work. If I save a patch I like, then maybe switch guitars, it might take a fair amount of tweaking to get the earlier happy result. Quote Link to comment Share on other sites More sharing options...
J_V_RO Posted March 20, 2017 Share Posted March 20, 2017 Well, not necessarily a Wampler OD pedal, but I use sometimes an L6 M5 on the FX LOOP (sounds crazy but I pair it with my hd500x, mostly to save DSP). Sometimes I use overdrives (placing the FX LOOP Block before the AMP/MIXER) or Delays/Reverbs (moving the fx block after the Amp/Mixer). Quote Link to comment Share on other sites More sharing options...
spaceatl Posted March 20, 2017 Share Posted March 20, 2017 I have a Strymon OB.1, BOSS DS-1 (modified TS), BOSS FZ-5 and BOSS LMB-3 (Limiter)...I have used them all with HD POD...Not in the loop, I just put them in line to the guitar input...leave the loop for post pedals like delays, etc.... Quote Link to comment Share on other sites More sharing options...
Indianrock2020 Posted March 20, 2017 Author Share Posted March 20, 2017 And you did this ( in one case to save DSP ) because you weren't satisfied with what could be accomplished with the built-in drive effects? Quote Link to comment Share on other sites More sharing options...
spaceatl Posted March 20, 2017 Share Posted March 20, 2017 I suppose partially sometimes I feel that way....To get just about everything the POD does, I have to add in my rack FX from my old ADA-MP1 rig....While those FX are true because they are the real deal...They always sound better...My SPX-990 has better reverbs, but it's harmonizer does not track as well...My Effection 1024s are fantastic delays... I often rehearse with the POD alone as it's convenient and I can get it done. However, I have a BCB board full of old BOSS pedals. I sometimes run an amp or two with only that board and no POD at all...Sometimes I make the mega rig and have all of it going. Just depends...The Strymon OB.1 optical compressor is unlike any compressor in the POD....It have a voiced clean boost on this...My DS-1 is modified and is a better sounding Tube Screamer than the models in the POD IMO, but I can get by with them fine...The DSP savings is kinda nice for of the complex patches. But I don't really need that in my current situation and frame of mind... There's no absolution to this...I am just an old guitar player that has a bunch of gear...We all go through phases with our rigs...Use what you feel like works...However, remember the tone chase never ends... ;) It just stops for a break here and there. Quote Link to comment Share on other sites More sharing options...
