Soultrainer Posted March 29, 2017 Share Posted March 29, 2017 Hi There is 4 ports in rack and 4 ports in control. Can I use all 8 of them or does it block for example port 3 from rack if I connect something to port 3 in control? I am thinking about buying cables and if I can connect exp pedal to control I need much shorter cables? Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 29, 2017 Share Posted March 29, 2017 There are 3 inputs for expression pedals on both Helix Rack and Helix Control. The fourth is for an EXP toe switch. The two devices share the same virtual inputs. So you can only use 1 EXP-1 pedal, connecting it to either device - not both. You can use a total of three, not six, EXP pedals. Quote Link to comment Share on other sites More sharing options...
Soultrainer Posted March 29, 2017 Author Share Posted March 29, 2017 There are 3 inputs for expression pedals on both Helix Rack and Helix Control. The fourth is for an EXP toe switch. The two devices share the same virtual inputs. So you can only use 1 EXP-1 pedal, connecting it to either device - not both. You can use a total of three, not six, EXP pedals. Ok thanks for a good answer. I have Cry Baby 95Q in front of Helix so 3 expression pedals is stil more than I need. Quote Link to comment Share on other sites More sharing options...
