Bangha Posted March 31, 2017 Share Posted March 31, 2017 So I had a little time to mess around with the new toys and was puzzled by the 3 Osc Synth. I went ahead and created a patch to see if I could use it as backing. You can hear a poorly recorded and played example here: http://vocaroo.com/i/s02xV3pmxcH1 Here's how it works: Set up to play a i - iv - V7 progression in Em the Em Am switch toggles between those two chords the B7 switch activates the V7 to return to the i or the iv (whichever was active before you entered the V), you stomp on the V again Synth volume is controlled by EXP Pedal 2 Is this the best way to go about programming the synth? I doubt it. Just a quick solution to the problem it posed. I've attached the the preset for those of you who care to give it a shot. Hopefully this is a little embryo we can all turn into something cooler on here. (to install it just remove the .txt format from the file name and use Helix editor) Enjoy! Paul - Synth Jam Em.hlx.txt 2 Quote Link to comment Share on other sites More sharing options...
Bangha Posted April 1, 2017 Author Share Posted April 1, 2017 Anyone? Helloooo? 1 Quote Link to comment Share on other sites More sharing options...
PierM Posted April 1, 2017 Share Posted April 1, 2017 Thanks for the input. Nice stuff. I'm programming one of my old FCB1010 with UNO Chip, to work as bass pedal, and seems working great. It's lot of fun! :) Quote Link to comment Share on other sites More sharing options...
