I need to record live a full rock band. 2 guitars will be direct line (chanel 1 and 2), bass and vocal will be line input chanel 3 and 4.
I would set up to run stand alone POD Farm to monitor both guitar.
Is that possible?
Monitoring thru DAW using POD FARM plug in brings a latency that is long enough to dificult the recording process.
How could I monitor in good shape bass and voice?
The idea is recording the drums with four mics while the musicians record monitoring guitars, bass and voice with headphones (i have a four split device to do that).
So the main problem is have good monitoring sounds on guitar and bass to record using POD farm at same time.
Can you help me to set up this session in my homestudio?
Make sure you are not daisy chaining your devices. Use a star connect configuration as much as possible, with the computer at the center of the star.
