pwik Posted April 4, 2017 Share Posted April 4, 2017 I just updated to 2.20 on Sunday from 2.10. Using Glen DeLaune patches. Have not had any issues until the update. At rehearsal last night my volume kept dropping out. If I moved the volume pedal it would come back. I remember there was a bug similar to this but thought it was resolved. Any suggestions other than rolling back to 2.10 (which I am not opposed to)? Quote Link to comment Share on other sites More sharing options...
duncann Posted April 4, 2017 Share Posted April 4, 2017 I thought they fixed this as well. I recall reading you may have to remove the volume block from the preset and add it in again. Quote Link to comment Share on other sites More sharing options...
brain-donor Posted April 4, 2017 Share Posted April 4, 2017 @JustStartin are you using Exp1 for volume or Exp2. I had this problem when using Exp1 for volume. Problem went away when I switched to Exp2. If that's not your situation I'm not sure what the problem is. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted April 4, 2017 Share Posted April 4, 2017 The EXP1 volume drop issue was supposed to be taken care of with 2.20. Maybe the volume blocks in the presets were created with a previous firmware revision, so the "bug" is still in the code for those presets. Maybe that's why they are saying to delete the volume block, and insert a new one, then save the preset. Quote Link to comment Share on other sites More sharing options...
