sizequeen Posted April 6, 2017 Share Posted April 6, 2017 I just tonight installed all of the newest updates to the Helix and the Line 6 updater, which includes the Helix PC software. Said software (Helix Edit I believe it is called) is acting very odd. When I go to the new patches 12D Line 6 Badonk I cannot see the actual amp/amp&cab block. It's just empty, as if there's nothing there. However on the Helix unit (floor model) I can see that it's the Line 6 Badonk amp. I can't select the Badonk amp when I create a new patch either, via the software, but on the actual Helix I can. It's like the software doesn't recognize the updated amp. It's not there in it's catalogue of amps to choose from. I have done the update 3 times now and that hasn't changed anything. Each time, obviously, I reset all of the global settings, factory presets, ir's, etc by holding down buttons 9 and 10 while turning on the actual pedal. I've reinstalled the latest Line 6 updater 3 times also, in hopes that the Helix editor would magically get fixed, but that hasn't helped either. Any ideas? I don't wish to edit patches on the actual pedal. I use the software out of convenience. Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 6, 2017 Share Posted April 6, 2017 It sounds like you are not using the current Helix editor v2.20. You need to download and install it separately. The Line 6 Updater program does not update the editor. Quote Link to comment Share on other sites More sharing options...
