Sign in to follow this
mapletop
delete setlist patches
did look for this option too and did'nt find. But you can import an empty setlist to the place of the one you want to delete ;)
You can't delete, you can only replace. Find or create a "new patch" with nothing in it and then replace all of the patches with that patch.
Next time you do an update - after you do the update BUT before you reload your saved setlists save a copy of one of the setlists that are totally empty and call it "Empty setlist".
Then reload any saved set lists you want and use the "Empty setlist" to clear out ALL THE CONTENTS of any "SCRATCH PAD" setlist you use for trying out sounds or just want to start over.
The only way to get rid of ONE preset is to load in a BLANK preset over it.
Good luck,  Bo
