channelk Posted April 24, 2017 Share Posted April 24, 2017 I know it can be done, but can't find how to do this. Want to turn on distortion and delay with one foot switch. Any help most appreciated. Quote Link to comment Share on other sites More sharing options...
Eric_Harbauer Posted April 24, 2017 Share Posted April 24, 2017 light up the effect block by moving the joystick, touch and hold the button you want to assign it to until the green checkmark pops up on the screen, press the knob with the green checkmark, highlight the next block and repeat the process. the scribble strip should read multiple (2) after you assign the second one. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 24, 2017 Share Posted April 24, 2017 light up the effect block by moving the joystick, touch and hold the button you want to assign it to until the green checkmark pops up on the screen, press the knob with the green checkmark, highlight the next block and repeat the process. the scribble strip should read multiple (2) after you assign the second one. You can also give the scribble strip a custom name that is more informative than "multiple(2)" as well as change the LED ring color. Using snapshots to assign multiple blocks to a switch is an option as well. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 24, 2017 Share Posted April 24, 2017 There's one potential quirk here. The display with the green confirm button also allows you to specify whether you want the assignment to merge with existing assignments (multiple fx with the same switch) or replace any current assignment with the specified single fx. Quote Link to comment Share on other sites More sharing options...
