twystedriffs Posted May 2, 2017 Share Posted May 2, 2017 When running a split path, and not merged so each path has it's own output, what does the balance control for each path in the split block do? Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted May 3, 2017 Share Posted May 3, 2017 It would operate the same way and simply feed the designated amount of signal to each side of the split I assume. I'm not sure a split block is even aware of what happens downstream. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted May 3, 2017 Share Posted May 3, 2017 When running a split path, and not merged so each path has it's own output, what does the balance control for each path in the split block do? I believe it is like a crossfade between the two paths. It can go from 100% A to 50/50 A/B to 100%B. Quote Link to comment Share on other sites More sharing options...
