camccr8 Posted May 4, 2017 Share Posted May 4, 2017 I think i might be missing something here, but when i have one guitar going to a boost, then a splitter going into 2 amps and cabs, almost all of the effects are grayed so i cant add reverb or delay or anything to either amp's path. What am I doing wrong and why is this small amount of stuff straining the DSP? Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted May 4, 2017 Share Posted May 4, 2017 Are you doing it all in DSP path? (i.e. everything is on the "top" path?) Two amp/cabs on one DSP path are not going to leave with many options, however if you send the output of the top path into the input of bottom path, you can load all kinds of effects in each chain on the second path. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted May 4, 2017 Share Posted May 4, 2017 I think i might be missing something here, but when i have one guitar going to a boost, then a splitter going into 2 amps and cabs, almost all of the effects are grayed so i cant add reverb or delay or anything to either amp's path. What am I doing wrong and why is this small amount of stuff straining the DSP? As gunpointmetal pointed out you may want to look into a "Super Serial x2" route which can leverage both DSP chips on the Helix into a signal path. You can find a template for it in the Templates setlist at 01D. Quote Link to comment Share on other sites More sharing options...
camccr8 Posted May 4, 2017 Author Share Posted May 4, 2017 that works, thanks folks! I am a Noob Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted May 4, 2017 Share Posted May 4, 2017 :) Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted May 4, 2017 Share Posted May 4, 2017 Most definitely! There's a lot of rock in these boxes. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted May 4, 2017 Share Posted May 4, 2017 You can also put in one amp/cab/effects per path (1 and 2) and both of them going to the multi output. It's like playing through two separate rigs simultaneously. You don't have to connect them super serially if you don't want. Quote Link to comment Share on other sites More sharing options...
